Firmware Updater SPC560BC Family
PChia.2237
Hi i have a custom board with SPC560B50L3 that is in the  SPC560BC Family.
There is no SPC560BC xx Firmware Updater Component.
If i try to add it (with shw incompatible components) of course i have problem generation files.
There is some alternative?
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
PChia.2237
OK, i copy all files and folders and component.mak from SPC560B xx Firmware Updater Component and it works!
PChia.2237
Erwan YVIN
Normally ,
if the component is incompatible , generation is failing , it is normal
could you check Firmware Updater test application ?
Best Regards
Erwan
