Control motor speed (Decrease)
Bastien1
I've got an issue.
I'm actually trying to control the speed of the motor with PWM signal.
I'm coding on SPC574S-DISP with SPC5 Studio.
With a Control engineering of the speed I can easily increase the speed, but I can't decrease the speed.
In fact, I can't slow down the motor because of its inertia.
How can I do that?
In advance, thank you for your response.
Respectfully
Bastien
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
3 REPLIES 3
Javier1
Principal
what kind of motor?
stepper motor? bldc? brushed dc motor?
In the case of bldc, are you using trapezoidal or foc modulations?
Maybe show us some code
we dont need to firmware by ourselves, lets talk
Bastien1
Thank you for the answer !
It's a DC motor
For my code, it's basically a loop for the speed with a PI correction
I dont think we can help you with this little info, try elavorating a bit more:
showing us the mdel of your motor and maybe some code helps
