2021-11-09 9:43 PM
An error occurred while collecting items to be installed
session context was:(profile=DefaultProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.st.spc5.components.L9908.spc5xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.l9907.spc56xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.l99asc03.spc56xx_rla,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.motorcontrol.demos.spc56xx,1.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.motorcontrol.spc56xx,1.0.0.202010121447
No repository found containing: org.eclipse.update.feature,com.st.spc5.components.spc5rla.spc56xx.motorcontrol.feature,3.0.0.202010121447
No repository found containing: osgi.bundle,com.st.spc5.components.stgap1s.spc56xx_rla,1.0.0.202010121447
2021-11-10 6:01 AM
Hello ,
Which update site do you use to install SPC56xx Motor Control Feature ?
No problem is noticed with
and http://mctkcust.spc5studio.com
Best Regards
Erwan
2021-11-10 6:01 AM
Hello ,
Best Regards
Erwan
2021-11-10 10:09 PM
Hello Erwan,
Thanks for your reply. I was finally able to install 3.0.0.
Initially, what I was doing was "Install New Software -> Add -> Archive" and then select the zipped folder en.MCTK_SPC5xxx_RTM_3_0_0_v3.0.0. This never worked ("couldn't find jar file" was the error message). Then, I unzipped the folder and selected content.jar file, and got the errors I posted above. Then, I tried "Install New Software -> Add -> Local" and selected the content.jar file and it worked.
Cheers!
Rassom
