BUG: Pin 144 not exist in PinMap editor for LQFP144 package
vromanov
Posted on November 03, 2014 at 23:17
How to reproduce
1) Open Spc5studio
2) Create test application for SPC56xL Discovery
3) Open PinMap Wizard
4) You can see pins 1-143. Pin 144 not exist
Also image not match to image on  SPC56EL70L5 documentation. Some pins moved from side to side. For sample pin 36.
This bug affect me. I can't assign pin mapping for CAN2 (A15-144)
#bug
3 REPLIES 3
Nickname2722_O
Posted on November 04, 2014 at 10:14
Hello
Vladimir, I reproduced the problem on my side.
I will update the model today, and it will be published on the update site just afterwards.
BR.
Ghislain.
Nickname2722_O
Posted on November 04, 2014 at 18:43
Hello Vladimir,
Please find attached the fixed model for your leopard.
In order to make it work you need to replace the file
SPC560EL_2M.xml
in your com.st.tools.spc5.wizard.pinmap.spc5.*** plugin.
- make sure that you update in the last version.
-the location is :
C:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.wizard.pinmap.spc5xxx\resources.
BR.
Ghislain.
________________
Attachments :
SPC560EL_2M.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qX3p&d=%2Fa%2F0X0000000bod%2FggKc8BFAINC2p9NwAC8EusMWyWcVQHbyGeN3qfW2GiU&asPdf=false
vromanov
Posted on November 04, 2014 at 19:36
Hello!
After replacing this file all ok!
Big tnx to you!
I'm very impressed speed of bug fixing!
