2014-11-03 2:17 PM
How to reproduce
1) Open Spc5studio 2) Create test application for SPC56xL Discovery 3) Open PinMap Wizard 4) You can see pins 1-143. Pin 144 not exist Also image not match to image on SPC56EL70L5 documentation. Some pins moved from side to side. For sample pin 36. This bug affect me. I can't assign pin mapping for CAN2 (A15-144) #bug2014-11-04 1:14 AM
Hello
Vladimir, I reproduced the problem on my side. I will update the model today, and it will be published on the update site just afterwards. BR. Ghislain.2014-11-04 9:43 AM
Hello Vladimir,
Please find attached the fixed model for your leopard. In order to make it work you need to replace the file SPC560EL_2M.xml in your com.st.tools.spc5.wizard.pinmap.spc5.*** plugin. - make sure that you update in the last version. -the location is : C:\SPC5Studio\eclipse\plugins\com.st.tools.spc5.wizard.pinmap.spc5xxx\resources. BR. Ghislain. ________________ Attachments : SPC560EL_2M.xml : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006qX3p&d=%2Fa%2F0X0000000bod%2FggKc8BFAINC2p9NwAC8EusMWyWcVQHbyGeN3qfW2GiU&asPdf=false2014-11-04 10:36 AM
Hello!
After replacing this file all ok! Big tnx to you! I'm very impressed speed of bug fixing!
