ADC0 interrupt problem
nooshin_1382
Posted on April 15, 2015 at 12:14
Hi
I Want to use , End of Conversion interrupt in ADC0 but when i set the NSTART bit in ADC0- MCR register in debug mode i saw in SFR view ,ADC0_ISR EOC bit is set but the interrupt is not work.
when i use while for this bit in my function i Read the ADC Correctly .
i Attach my code here if my code have problem please let me now.
thanks
With Best Regards
Nazerian Vanima
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
1 REPLY 1
Erwan YVIN
Posted on April 20, 2015 at 10:46
Hello Vanima ,
Could you attach your sample code ? before setting the NSTART. enable the IMR
/* Enable the ADC Interrupt */
/* Set the interrupt Mask Register */
adcp->adc_tagp->IMR.R=ADC_IMR_MSKEOC|ADC_IMR_MSKECH;
you should set CIMR (Channel Interrupt Mask resgister). Best regards Erwan
