2019-09-18 7:44 AM
I'm experimenting the example SPC560Pxx_RLA PIT Test Application for Discovery.
It is simply a 3 led flashing using PIT.
Is it possible that the frequency of the example is wrong? It is exactly doubled, instead of 4,2,1 Hz
i read 2,1, 0,5 Hz.
The quartz on the board is exactly 12 MHz.
2019-09-20 3:27 AM
This post is to delete! I understood the error that I made
2019-09-20 3:27 AM
