2025-11-01 1:40 AM - last edited on 2025-11-01 5:02 AM by Peter BENSCH
Hi. I'm looking for a programmer for SPC564L60L5. The best would seem SPC5-UDESTK but it is not available for sale. Or maybe StellarLINK It will be ok for full programming and debugging support for this chip. Or maybe some other suggestions of a programmer who would support SPC564L60L5?
Thank you for your help
Best regards Christopher
2025-11-17 2:12 AM
Hi there,
Actually, you do not need the license hightec to run AutoDevKit or flash your boards.
But ,if you want to remove the annoying hightec message, take a look to this thread.
Regarding PLSUDE, (our legacy flashing method) you can find some resources here.
We recommend switching to OpenOCD technology, using our new AEK-MCU-SPC5LNK (here you can find the drivers)
Anyway,
If you are looking for support to reverse engine or fix an existing ECU, I'm sorry but you should contact the manufacturer.
Best regards,
Simone
AEK_Team
2025-11-01 10:49 AM
You can use AEK-MCU-SPC5LNKU, it is equivalent and available on e-stores.
Best Regards,
AutoDevKit Team
2025-11-02 1:43 AM
Thank you for your reply. It has already been ordered. And if it turns out that the chip has a password, is there any way to decrypt it?
2025-11-02 10:16 AM
If you are talking about the FTDI chip on the programmer, I confirm that there is no password.
The chip comes with pre-programmed license UDE from PLS. It is free up to 256KB of code to be downloaded.
Best Regards,
AutoDevKit Team
2025-11-06 1:17 PM
No, I'm talking about the chip SPC564L60L who is in the airbag controllers That I would like to fix and unlock it. Is it possible to decrypt the password to access epprom memory? Or flash etc?
2025-11-07 12:04 AM
Hi there,
No, it's not possible.
Best regards.
2025-11-16 8:07 AM
Where can I download the UDE version assigned to my AEK?
And how can I get a free license for SPC5Studio? Every time I launch the application, a prompt appears saying that the license is not active. I went to the website at the bottom of the window, filled in all the fields to get a free license, but unfortunately nothing came of it.
Best Regards Christopher
2025-11-17 2:12 AM
Hi there,
Anyway,
Best regards,
Simone
AEK_Team
2025-11-17 10:35 PM
Thank you for your Help
Best regards
Christopher
