TS922: Can the TS922 operate with +5V on VCC and -5V on VDD without issue?
PPage.3
I like everything about the TS92X series, I just need to know if there are any issues with operating the TS92X series with dual supplies (+5/-5V).
7 REPLIES 7
Antoine Cros
​Hello,
Maximum operating Vcc is 12V, so, yes TS922 can operate at +/-5V in dual supply.
Best regards
PPage.3
I assume this is the same answer for the TS921 since they are the same series, correct?
Antoine Cros
​Sure, this is correct also for TS921.
PPage.3
Thank you for the quick responses! Have a great day!
Antoine Cros
​Thanks to you ! Sure this is a great circuit, what features are most valuable to you ? Do you use it for a specific application ?
Best regards
Antoine
PPage.3
The fact that it's unity gain stable with high output current. I'm using this in a GaN device gate bias network.
Antoine Cros
​Thanks for the info !
