TDA756x Is safe to drive speakers with lower gain?
YSun.7
to decrease output noise, can I use 16db gain to drive 4ohm or 8ohm speaker with tweeter in low volume.
"Selectable gain 26 dB /16 dB (for low noise line output function)" in datasheet but no only shown.
Peter BENSCH
Welcome, @YSun.7​, to the community!
If I understand your question correctly, you want to reduce the output noise by setting gain to 16dB?
Yes, the output noise will be reduced, but also the volume by (16dB-30dB) = -14dB.
/Peter
1 REPLY 1
Peter BENSCH
/Peter
