2015-03-19 4:02 AM
Is there a replacement for the TDA2003 or can any one recommend a similar audio amplifier that can drive loads down to 1 ohm?
#tda20032015-03-19 5:50 PM
hi Mark ,
You may check TDA2009A , the output current capability is same with TDA2003 . but TDA2009A is for stereo output configuration . Thanks to consider ST device.
