Noise Analysis and SPICE Model for TS9224
Posted on August 01, 2012 at 21:19
I am working on an instrumentation amplifier circuit.  I would like to perform a noise analysis on the circuit and would like to get a SPICE model for the TS9224 opamp.  I am using LTSpice.  I could also use some help in understanding the output I get from the noise analysis.
Scott Gauche
#ts9224-noise-spice
1 REPLY 1
Pierre SENNEQUIER
Posted on August 06, 2012 at 15:52
Hi Scott,
   You can download the spice model at : http://www.st.com/internet/com/SOFTWARE_RESOURCES/HW_MODEL/SPICE_MODEL/ts92x.txt
This model has been designed for a first order simulation level and is not featuring noise analysis capability.
  Regards.
In order to give better visibility on the answered topics, please click on "Accept as Solution" on the reply which solved your issue or answered your question.
