I have 2 mosfets with next numbers on them.. 09362913 8807a635 V6 88 SGP 09375459 2201L BC VH MLT 22 638 Please, can you tellme what TDA code are? Thanks a lot!
JRIVE.1
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Probably..
TDA7294 Multiwatt 15 / ZIP 15
https://www.st.com/resource/en/datasheet/tda7294.pdf
TDA7851L Flexiwatt 25 / ZIP-25
https://www.st.com/resource/en/datasheet/tda7851l.pdf
Probably..
Thank you!
