Hello there, I'm trying to fix some issue with an audio valve preamp and need to find voltage regulator to replace old one which is a N940 from ST, but I can't find any info about it, do you know any datasheet about it or replacement part ? best regards
RREMI.1
4 REPLIES 4
Imagine this is probably a transistor, not a regulator
The N940 is a production/date code
The part number looks to be TIP90, perhaps TIP30, hard to read, need a better/clearer picture of the third line.
RREMI.1
yes it's written TIP90
thanx a lot for identifying the type transistor ! ��
best regards
I don't find any datasheet about this one or some pieces to buy..
maybe you know some other that can replace it ?
best regards
I beg your pardon, I just had a look closer and it's a TIP50, just found it.
Thank you for the help
best regards
