Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
STAudioHub time drifts
Posted on June 13, 2017 at 16:45On the steval-mki138 MEMS microphones dev kit, using the STAudioHub firmware and tools, I am observing a significant time drift between 2 developments kits acquiring the same audio signal at the same time. I am now lo...
Can under-powering an OpAmp Damage it (TSV358AIDT)
Posted on June 09, 2017 at 05:47We are seeing some of our opamps failing, outputting the VCC rail regardless of input!The input signal is a BLDC fan current sense resistor and cell a is a non-inverting gain of 3x.Our sleep circuit was implemented in...
Connecting Audio USB controller in VL812 USB 3 HUB
Posted on June 02, 2017 at 08:40Hello ,Could you kindly recommend me any STM  kit that can be applicable for MEMS microphone ?This kit should be USB interfaced with PC, my plan is to connect it to VL812 USB 3.0 Hub Controller .Is it possible to make...
How to use osxAcousticEC library to mass production?
Posted on May 24, 2017 at 10:06We use osxAcousticEC library on STM32F401CBY6.For only one MCU, we can use OSX LicenseWizard to get license and this function is ok.But we are going to mass production, could you tell me how to batch obtain license? Th...
TDA7492P SVCC, SVSS, and PGND
Posted on May 26, 2017 at 23:10HiLooking at the TDA7492P, but this seems to apply to the TDA749xxx devices as I checked those data sheets too.SVCC (35) and SVSS (36). Is the schematic correct? Do I simply connect the two with a cap, but neither to p...
jguy by Associate
  • 822 Views
  • 0 replies
Posted on May 24, 2017 at 10:10We use osxAcousticEC library on STM32F401CBY6.For only one MCU, we can use OSX LicenseWizard to get license and this function is ok.But we are going to mass production, could you tell me how to batch obtain license? Th...
TDA7491HV getting very hot?
Posted on May 15, 2017 at 09:10I am having problems, with a TDA7491HV design (taken directly from the http://www.st.com/resource/en/datasheet/tda7491hv.pdf - Figure 50) and although it is working, the output inductors are getting very hot. Hot means...
ADC multichannel
Posted on May 02, 2017 at 21:14How to make a code from 2 channels for conversion.please!!
