2017-05-15 12:10 AM
I am having problems, with a TDA7491HV design (taken directly from the
http://www.st.com/resource/en/datasheet/tda7491hv.pdf
- Figure 50) and although it is working, the output inductors are getting very hot. Hot means ~85C with an ambient temp of 15C.I have read elsewhere on this forum that
has use (with success) a 'filterless' output stage with the TDA7491LP.Does anyone know if this approach is feasible for the TDA7491HV? There is no equivalent to
http://www.st.com/resource/en/datasheet/tda7491lp.pdf
in the TDA7491HV datasheet.Best regards, Martin
