Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
ST audio IC with SPI
for reading micro sd audio data (SPI), I need to choose a Audio IC with Vol +, Vol-, next and pre funtion. Anyone How has expereince with that?Thank you
ABous.2 by Associate
  • 649 Views
  • 0 replies
May we use TSA4871 in single singled mode?
On a existing Electronic board, the following schematic is implemented:May I use it in single end mode with a serial capacitor between VS+ (or VS-) and the load connected to GND?May the other output VS- (or VS+) stay unconnected?What is the bias volt...
SBour.2 by Associate
  • 667 Views
  • 0 replies
TS3022 - Clamp overvoltage in ESD input diodes ?
Good morning,I am working on a basic test bench application and considering the TS3022, unfortunately the inverting input voltage may go beyond the VCC rail (which I cannot avoid due to pre-existing architecture).I am wondering:is there integrated ES...
Gleme.1 by Associate
  • 785 Views
  • 0 replies
Real-time clock M41T62 per day leave for 6 minutes henceforth
Real-time clock M41T62 per day leave for 6 minutes henceforth. I found out that the quartz frequency is about 32.9 kHz. Program calibration does not reduce this inaccuracy. Do I have a defective chip or I don’t understand something?
AGari by Associate II
  • 1544 Views
  • 3 replies
GM68020H datasheet need
Hello,i want to use GM68020H to research ,but i can't find out its detail data sheet ,can you send one to me?My email :2664822931@qq.comThank you very much!
Djie.1 by Associate II
  • 2649 Views
  • 8 replies
  • 1 kudos
STPM34 Line and Neutral connection
I have used STPM34 In my design. I am measuring voltage and current of single phase supply. Line is connected Pin number 9 of STPM34 and neutral is connected with circuit ground via ferrite bead. check R23 in schematic. I have attached schematicMy...
RKara.1 by Associate
  • 739 Views
  • 0 replies
