Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
TDA7450 datasheet
Please provide datasheet for old audio amplifier, commonly used in car radio. It is marked as TDA7450. Screenshot from service manual on Grundig AD182 in attachment. It has unusual connection. May be any other IC can be used instead of this one.
SZhyl.1 by Associate
  • 1331 Views
  • 0 replies
关于tda7564b功率
你好,我想请问一下tda7564b,支�?多大w数的扬声器,最大与最�?。谢谢
赵赵.1 by Associate
  • 822 Views
  • 0 replies
Amplifier - TSC2011 - PSPICE Model Question
Saw that ST provides library for all models together, but what about the .olb file for the schematic representation. Does that need to be created for each part on my end, or am I missing something?
JP-FMT by Associate
  • 830 Views
  • 0 replies
I am trying to sample data from PDM microphones using DFSDM and then output the audio using SAI setup as a master PCM interface. Is there a way to synchronize the data coming from the DFSDM with the SAI setup in Master mode?
I can get the frequencies close but not exact. I currently have a circular DMA buffer that I put the data in as I receive it from the DFSDM which feeds the SAI. I have this working but since they aren't exactly the same frequency there is underrun or...
dhedin by Associate
  • 1022 Views
  • 0 replies
