Why my stm8s103f3 can not enter into uart rx interrupt?
cgh21
Posted on April 14, 2011 at 19:23
5 REPLIES 5
cgh21
Posted on May 17, 2011 at 15:12
PS:
I am using cosmic 4.3.4+stvd.
richb
Unless I miss my guess, you are missing the UARTx_Cmd(ENABLE) command, but it could also be the 'overrun' part of your interrupt enable call.
Here is my code for UART3 that works (using receive and transmit interrupts):
    UART3_Init(38400,
               UART3_WORDLENGTH_8D,
               UART3_STOPBITS_1,
               UART3_PARITY_NO,
               UART3_MODE_TXRX_ENABLE);
    UART3_Cmd(ENABLE);
    UART3_ITConfig(UART3_IT_RXNE, ENABLE);
Hope that helps
cgh21
As far as i know,there is no need to excute UART_CMD(ENABLE),But i tried, the same.Thanks for your information.
Chris
wen
Posted on September 29, 2011 at 11:36
 use the register is the fast
mighel84
Posted on October 18, 2011 at 18:28
If you don't ENABLE the peripheric will not power up or the clock signal will not be connected to uart internally.
If problem persist try with your compiler getchar putchar functions.
