The problem with calculations on types float with Cosmic compiler
krzysztof239955_st
Posted on October 02, 2009 at 09:13
4 REPLIES 4
krzysztof239955_st
Posted on May 17, 2011 at 15:04
Why variable wsp_kal not have after the calculations of the correct value 0.000038?
Example:
float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal;
masa_kal = (float)(mas_kal[i+1]-mas_kal[i]); // correct 5
dzal_kal1 = (float)kal_ram.dz_kal[i+1]; // correct 329602
dzal_kal2 = (float)kal_ram.dz_kal[i]; // correct 198530
dzal_kal = (float)(dzal_kal1-dzal_kal2); // correct 131072
wsp_kal = (float)(masa_kal/dzal_kal); // incorrect 0
mozra27
What is the compiler used in your application and what is the optimization level?
Please check with the following declaration:
float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal = 0.0;
mozra
krzysztof239955_st
I use STVD 4.1.2 and the compiler Cosmic CxSTM8 4.3.1 with optimizations: Minimize code size (+compact). Declaration: float masa_kal,dzal_kal1,dzal_kal2,dzal_kal,wsp_kal=0.0; - not bring the improvement.
Best regards
krzysztof239955_st
The setting Display Item from Decimal on Standard in debuger solved the problem.
Best regards
krzysztof.skoczek
