Strange value of register
adaszeq
Posted on February 24, 2013 at 09:08
I have one strange problem. After this fragment of code program:
b = a;
a =/ 40;
if(!a)
//breakpoints
the results of two registers are: b = 50000 - good value,
a=0
The value of a should be about 1250 not 0!!
I can't find place in my program where i change value of a, because I use it only in one place.
Any suggestion how can I find solutions of this problem?
#incorrect-expectations #wrong-value-register-bug #optimisation
4 REPLIES 4
Andrew Neil
Posted on February 25, 2013 at 10:07
You have not given enough information.
Post the smallest complete  program which illustrates your problem...
luca239955_stm1_st
Senior II
Posted on February 26, 2013 at 09:03
most likely something has been optimized away: first step is to declare the variables as volatile and see if you get the expected value.
Andrew Neil
Posted on February 26, 2013 at 19:46
''declare the variables as volatile and see if you get the expected value''
If you do, that may well be an indication that the expectation  was flawed...
http://bit.ly/Vv8fFg
richhamersley
Posted on March 04, 2013 at 17:16
Did you mean:  a /= 40;
i.e., a = a/40;
instead of a =/40?
a =/ 40;  if accepted by compiler will always set a to 0.
