STM8S103 problem with ++
adriano2
Posted on October 08, 2009 at 13:09
adriano2
Posted on May 17, 2011 at 15:05
Dear All
I have a too strange behaviour with the following code:
while (HS_Values_X[uC++] < Conversion_Values[0]);
HallAngle[0] = HS_ANGLE_X[uC-1];
In fact, by following the code step by step with the debugger uC variable increase three by three any step (and not by one).
I changed the firwmare:
while (HS_Values_X[uC] < Conversion_Values[0])
uC++;
but I obtain the same strange behaviour. Why?
Some one could help me!?! I have set the compiler in order to minimize the code size.
mozra27
Hi Genius,
The uC variable should be declaration as volatile... thanks to check this point.
mozra
adriano2
I solved and the problem is the STVD IDE, in fact I had the HS_Values_X[uC++] term in the Watch. By removing it from the watch all work.
For some strange reason the Watch modify the variable :-Y
thanks
