Stm8S003f3 debugger
MKıyı.1
I am using Stm8s003f3 in my own designed card. Using ST-LINK v2, I can assign code using SWIM and RESET pins. I'm getting an error when I want to upload more than one stm8 code using the same debugger. Is there a product or method that I can use to proces
3 REPLIES 3
Peter BENSCH
Welcome, @Melih Kıyı​, to the community!
What do you mean by uploading more than one stm8 code with the same debugger?
How does the error message look like?
/Peter
MKıyı.1
Code throwing process by multiplexing the SWIM and RESET pins on the debugger on the breadboard and connecting to the SWIM, RESET pins on more than one stm8s003f3.
Error : Failed to set configuration with MCU name STM8S003F3: SWIM error [30004]: Comm timeout
WilkoL
Senior
Do you mean using those pins for other purposes than SWIM and RESET in you program? E.g. to use them as an input or output?
