STM8S Discovery firmware - LCD display pinout
admin239955_st
Posted on September 15, 2010 at 22:16
Hello
I'm trying to connect LCD display (WH1601A) to the demo board and use firmware SPI module and SPI_SimplexLCD example as base of my code.
But I can't see which PINs (ports) I should use to connect LCD display or where I can select MCU port. I found only ChipSelect and Backlight PINs configuration code (in
https://my.st.com//public/STe2ecommunities/mcu/Lists/STM8SDiscovery/mono__lcd_8h.html
). Could you please help me configure data port of say which port was used in sample program?
Dmitry
null
4 REPLIES 4
mmaana
Posted on September 16, 2010 at 06:40
Hi, Dmitry!
File mono_lcd.c is part firmwire for demoboard STM8/128-EVAL, LCD use on this board have SPI interfice, as connect this GLCD may see on schematic board (doc UM0842 -
http://www.st.com/mcu/familiesdocs-113.html
But why SPI? WH1601A not work in SPI mode.
I use 4-bit mode for WH1602 on my STM8S-Discovery and no problems.
Petr.
Regards!
admin239955_st
Posted on September 16, 2010 at 08:50
Petr,
Thanks for you answer! I'm novice in MCU programming and firmware would help me with my experiments. I found couple libraries which work with LCD but was thinking firmware using is better way. I found LCD management example which uses SPI and planned modify them a little.
But now I'm going to try with third-party libraries.
Dmitry
mmaana
Posted on September 16, 2010 at 09:38
Hi, Dmitry!
If you new in world programming MCU, the fastest and simplest way (IMHO) to your case here
http://atomsoft.wordpress.com/2010/03/08/lcd-on-stm8s-discovery/
Regards!
Petr
admin239955_st
Posted on September 16, 2010 at 13:38
Petr,
I'm already trying with this example;)
