2015-07-16 01:25 AM
Hi all!
ST Visual Development Raisonance Debugger Cosmic Compiler The following problem: It seems that the internal EEPROM is erased every time the debugger writes new software into the controller. Is it possible to tell the debugger NOT to erase the EEPROM? Because all the init data is lost .... :-(2015-07-20 03:20 AM
2015-08-27 01:18 AM
Thanks! It works .... :-)
