2014-05-22 4:09 AM
Dear All,
I've been discovering STM8 core capabilties and properties for a while. I've had a chance to read datasheet for STM8L152. But I couldn't find detailed register info. For instance, CCR (Condition Code) register bit definitions are not clear as far as I saw. Do you have a source (document/web site etc.) to recommend?Best Regards,Batu2014-05-22 6:43 AM
Hi
As is with ST - they spread all the information among many documents! The STM8 core is described in the 'Programming Manual' http://www.st.com/web/en/resource/technical/document/programming_manual/CD00161709.pdf Each processor (eg the STM8L152) will have a data sheet describing the specifics2014-05-23 1:22 AM
Dear Mr. Chung Sung Chen,
Thank you for your relpy. I didn't know the information that I'm searching was shared in the programming manual (I was expecting it in the datasheet). Actually I had downloaded that document but I was supposing the document content was only about instructions and their explanations. Again Thank you, Best Regards, Batu
