Pull Up pin
bruno2
Posted on May 26, 2014 at 20:55
Is there some way to turn off a pull up input for some time and later turn it on on a certain frequency?
The pull up pin drain too much current.
3 REPLIES 3
abbas
Posted on May 27, 2014 at 09:15
you can use a timer interrupt handler to turn pull up on and off at a certain frequency
bruno2
Posted on May 27, 2014 at 12:55
How can i do that? Can you send me an axample?
abbas
Posted on May 27, 2014 at 14:10
for example, you config one of your timers like this
void TIM1_Config(void)
  TIM1_DeInit ();
  TIM1_TimeBaseInit (TIM1_PRESCALER, TIM1_COUNTERMODE_UP, TIM1_PERIOD, 0);
  TIM1_ITConfig (TIM1_IT_UPDATE, ENABLE);
  TIM1_ARRPreloadConfig (ENABLE);
  TIM1_Cmd (ENABLE);
and in interrupt handler you can do like this, flag_pull_up must be defined as a global variable
INTERRUPT_HANDLER (TIM1_UPD_OVF_TRG_BRK_IRQHandler, 11)
  if (flag_GPIO_pull_up)
    GPIO_Init  ( GPIOx,  GPIO_Pin, GPIO_MODE_IN_FL_NO_IT );
  else
    GPIO_Init  ( GPIOx,  GPIO_Pin, GPIO_MODE_IN_PU_NO_IT )
    // write your routine
  flag_GPIO_pull_up
flag_GPIO_pull_up
  TIM1_ClearFlag(TIM1_FLAG_UPDATE);
