Problems with JP and CALL instructions
newtonpro
Posted on September 07, 2011 at 15:38
When the JP instructions jump less than 92H I haven't any problem, but if it jumps more than 92H the JP and Call command do not work properly. I am sure to be in the same section because I use STM8S105C6.
Example1:
0x80E8 jp Base
if the label Base is an address 0x8110 the compiler translates in JP 0x8110 >>Correct
if the label Base is an address 0x8181 the compiler translates in JP 0x8081 >>Wrong
if the label Base is an address 0x8259 the compiler translates in JP 0x8159 >>Wrong
if the label Base is an address 0x8349 the compiler translates in JP 0x8149 >>Wrong
if the label Base is an address 0x83B5 the compiler translates in JP 0x80B5 >>Wrong
Example2:
0x83DD jp Base2
the label Base2 is an address 0x8685 the compiler translates in JP 0x8085 >>Wrong
After 0x817B every label must have the ''.w'' suffix for ex: Base.w
The call instruction is the same.
Why? Did I forget a few assembler directives?
5 REPLIES 5
brazov22
Posted on September 07, 2011 at 15:53
try JPF/CALLF instructions
newtonpro
Posted on September 07, 2011 at 19:34
Already tried is the same
newtonpro
Posted on January 31, 2012 at 15:20
The same problems there are with the STVD ver. 4.3.0.
If there are some errors during compiling the STVD ver. 4.3.0 go to crash. There is a bug?
marcosovilla9
Posted on February 15, 2012 at 14:33
Hi Marco,
also to me it happens: STVD 4.3.0 crashes when it founds errors. With STVD 4.3.1 they corrected this problem but I found another problem about SWIM communication when starting debug, so I'm actually using STVD 4.2.0 , because it's the only that works fine!!
newtonpro
Posted on March 01, 2012 at 13:07
It was necessary before  ''  segment 'rom'  '' write WORDS.
With this word the problems go away.
