ON/OFF Microcontroller
‎2018-01-19 7:09 AM
We are using STM8L051F3 and it has 2 inputs which is 2 key keypad which we are using for our application. Now i want to use that keypad for ON/OFF of microcontroller also.How i can do that? I want to ON controller power supply when i press keypad key and then i will use those key for my application also and then if i key for long time or press both keys it will OFF, i.e. power supply cut off. This is like our old keypad mobile phones which has 1 key for Mobile phone ON and that same key we can use for receiving call also. How can i do that for my STM8L051F3?
‎2018-01-19 7:35 AM
Maybe these materials will be useful to you:
https://sourceforge.net/p/s3-code/code/ci/master/tree/superbutton/
‎2018-01-19 8:55 PM
Hi thanks for response, Yea i can do that longer button press detection using timer. Main thing is hardware i think, That i want to give power supply to controller using 1 button not switch, means if i pressed once power supply goes to controller then our application will work and if i pressed that button little longer it will off. Problem cant be solved by just code i think, it needs hardware. So i built latch circuit which gets ON when i press a key and our controller gets power supply but then i cant use that key for my application as it is always high, as it is base pin of BC547.
‎2018-01-19 11:27 PM
It is how you want. Modern micro-controllers do not need to remove power.
The current consumption in sleep mode is very small. A wake up the
controller can be executed by the same button, connecting it to the wake up
input signal.
‎2018-01-20 12:25 AM
So there is no way to completely off microcontroller?
‎2018-01-20 1:34 AM
Is need small external electronics circuit for complete switch off the
micro-controller by SPST push button.
‎2018-01-20 2:09 AM
I found one circuit but i don't understood its working 100%, kindly check the link
‎2018-01-20 2:32 AM
It's original. What you do not understand specifically? The author described the principles of the circuit quite well. You can improve your skills in circuitry understanding by study special education courses.
