Microcontroller suggestion for OHC Automotive Design
KBAROT1983
HI ST Support
We are looking a microcontroller for our new Requirements, Please look below details and suggest.
Project Name : Overhead Console
SOW : Design Complete electronics of OHC with Rear light control. There will be some Touch Switch to detect and turn ON/OFF/Dimming/sunroof Slide the LED light based on feedback. OHC will Communicate to BCM on LIN Channel.
Block Diagram (Minium 16 Touch require)
SWITCH 1 OHC LEFT LAMP (TOUCH ENABLE)
SWITCH 1OHC RIGHT LAMP (TOUCH ENABLE)
SWITCH 3-7 Sunroof Silding (TOUCH ENABLE)
SWITCH 8-12 Sunroof shade Sliding (TOUCH ENABLE)
SWITCH 13 Ambient Light Switch (TOUCH ENABLE)
SWITCH 14 Door Control Switch (TOUCH ENABLE)
SWITCH 15 I-CALL Switch(TOUCH ENABLE)
SWITCH 16 B-Call Switch(TOUCH ENABLE)
Please suggest Microcontroller
  • LIN Slave stack support from Vector (MICROSAR).
  • Automotive grade, FUSA AISL-B Microcontroller
  • Integrated touch controller for touch switch implementation.
Kunal Barot
7016323429
1 REPLY 1
Peter BENSCH
Welcome @KBAROT1983, to the community!
Please note that this is the community where worldwide users of STMicroelectronics components help each other. If you want to contact the support confidentially and get a personal answer from them, please create a ticket in the Online Support OLS. Alternatively you can contact your local distributor.
Good luck!
/Peter
