How to arrange the variables at EEPROM using COSMIC ?
jeffrey23
Posted on May 14, 2010 at 10:06
5 REPLIES 5
luca239955_stm1_st
Senior II
Posted on May 17, 2011 at 15:08
@eeprom tEGD tsEGD;
@eeprom tEYD tsEYD;
Luca (Cosmic)
jeffrey23
Hi Luca,
I tried to declare the variables as you mentioned.
But I got some error messages as attachment.
#error clnk Debug\A101VW01.lkf:1 symbol _FLASH_CR2 not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o )
#error clnk Debug\A101VW01.lkf:1 symbol _FLASH_NCR2 not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o )
#error clnk Debug\A101VW01.lkf:1 symbol _FLASH_IAPSR not defined ((C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepstr.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eeprom.o (C:\Program Files (x86)\COSMIC\CXSTM8_16K\Lib\libm0.sm8)eepwrp.o
Boltnut
B.Montanari
Hi Boltnut,
On your main.c (or any used header) declare this:
/*    FLASH section
volatile char FLASH_CR1     @0x505a;    /* Flash Control Register 1 */
volatile char FLASH_CR2     @0x505b;    /* Flash Control Register 2 */
volatile char FLASH_NCR2    @0x505c;    /* Flash Complementary Control Reg 2 */
volatile char FLASH_FPR     @0x505d;    /* Flash Protection reg */
volatile char FLASH_NFPR    @0x505e;    /* Flash Complementary Protection reg */
volatile char FLASH_IAPSR   @0x505f;    /* Flash in-appl Prog. Status reg */
volatile char FLASH_PUKR    @0x5062;    /* Flash Program memory unprotection reg */
volatile char FLASH_DUKR    @0x5064;    /* Data EEPROM unprotection reg */
This should solve your problem
Bruno
B.Montanari
jeffrey23
Hi Bruno,
Thanks for your help. It fixed my linkage issue.
jeffrey23
Hi Bruno,
As you suggested, I tried to add the FLASH section for solving the linker issue.
Unfortunately, its behavior is wrong even linkage issue was fixed.
Could you give me more suggestion ?
Therefore I changed back original declartion. It can work fine.
EXTERN tEGD tsEGD   @0x4000;
EXTERN tEYD tsEYD   @0x4020;
            /* Unlock Data memory */
            FLASH_Unlock(FLASH_MEMTYPE_DATA);
            if (fDown)
                if (tsEGD.bBrightness > BRIGHTNESS_MIN)
                    tsEGD.bBrightness--;
            else
                if (tsEGD.bBrightness < BRIGHTNESS_MAX)
                    tsEGD.bBrightness++;
            /* Lock Data memory */
            FLASH_Lock(FLASH_MEMTYPE_DATA);
