How to declare a string array for STM8S103F3 using COSMIC ?
jeffrey23
Posted on May 17, 2010 at 18:25
1 REPLY 1
luca239955_stm1_st
Senior II
Posted on May 17, 2011 at 15:08
in your declaration, the first ''const'' keyword tells the compiler that the pointed object (your strings) is a constant, while the second ''const'' keyword tells that the pointer itself is a constants (ie, its value will never change).
Depending on what you are actually trying to do, the second ''const'' might be useless/wrong.
Regards,
Luca (Cosmic)
