how to change c language from c90 to c99 in stvd
‎2021-02-09 10:26 PM
I am using STVD to debug program for stm8s105c6 MCU. Here am able to compile code properly, and using cosmic compiler.
I am getting error for Inline, and also prototype missing, semicolon missing, invalid constant expression, etc. errors are coming.
Do they are occurring due to c language standard version or anything else?
Please guide.
Thanks in advance.
‎2021-02-09 10:59 PM
The supported standards and the compiler flags for processing a module should be specified in the toolchain manuals.
I had never been working with the Cosmic compiler.
The inline error is probably standard related, the others are likely not.
Check you MCU header file for compiler-dependant #if /#ifdef sections.
Perhaps a toolchain define is missing, and you pull the wrong toolchain-dependant definitions.
‎2021-02-10 1:38 AM
