Hello
We use an advanced timer with an internal clock of 16 MHz in input capture mode
We give a pwm signal to tim1
We want Measure the D.Cycle of each pulse
Question: What is the maximum frequency that can be given to the input?
Options
2022-02-10 3:15 AM
Options
2022-02-10 3:56 AM
Not a STM8 user but presume it would depend on the resolution/granularity you expect in the results.
For useful duty cycle measurements, perhaps a few hundred KHz.
If servicing interrupts, likely bound by those saturating too.
1 REPLY 1
Options
2022-02-10 3:56 AM
