hello sir i use the st development program
debruyne.marc
hello sir
and have a problem with the assembly code "int 040200"
if you write that , the st development does not accept that code, altough its in that way it mentioned in the manual
please can you help me, how to solve that
many thanks
marc debruyne
8 REPLIES 8
You asked this yesterday.
Not much STM8 support to be had here.
What error does the assembler give? Any examples of similar usage? Any compiler or disassembler generated code using this or similar instructions?​
hello sir
thanks for youre answer
well indeed its i use the stv development stm tool an i selcet stm assembler
then if i write that assembler line "int  $040200"
the assembler tells me its not the a correct instruction
so then i ask you witch is the correct instruction then
certainly its so marked in the manual, but in reality its not accepted
by the stm8 assembler
i had already a similar problem but with "sub SP,#4" and it came out
that its be changed to "subw"SP,#$4"
hope you can help me sir
many thanks
marc debruyne
Op 20/10/2022 om 14:06 schreef ST Community:
Do you know what the opcodes for the instruction should be?
How do they report in a debugger, or disassembly, in ST's or COSMIC's tools?
https://community.st.com/s/question/0D53W00001sKYf6SAG/regarding-the-stv-assembler
Can only be used in the Interrupt Table (check section/attributes where used, likely $00.8000 .. $00.807F)
0x82 ($82) OPCODE INT
INT $2FFFFC
82 2F FF FC
Could try INT #$2FFFFC
or INT symbol
https://www.st.com/resource/en/programming_manual/pm0044-stm8-cpu-programming-manual-stmicroelectronics.pdf
If all else fails, create a MACRO, or define/emit byte stream for the encoded instruction
Here they construct the interrupt table via a DC.L
http://stm8sdiscovery.nano-age.co.uk/adventures-in-stm8-assembler/revenge-of-the-blinking-led
; the interupt table
    segment 'vectit'
    dc.l {$82000000+start}                                ; reset
hello sir
thanks for youre effort to help me
realy i all have tryed that
" ldw X, (X)
    neg A
    rlwa X, A
    int #$040200
;    nop
;    nop
;    nop
;    nop
    rlwa X, A
thats the error code the assembler gives me, but i try to over come that
just temporaly with 4 nop
main.asm(2378): as1 : Error 56: unrecognised opcode '    int #$040200 '
sir, maybe i am a "stupid  71y old man" but me too i am an electronique
engeneer, and have already programmed since,
8080-6502-6802-6809-atmega2560-cop8-,
and realy i tryed all, be sure i would otherwise not at all asked youre help
many thanks
marc debruyne
Op 20/10/2022 om 15:50 schreef ST Community:
Contextually this looks wrong. Is this coming from some sample/example, or you just trying to code something?
I'm not sure it's available as a 24-bit call instruction, but I'm not an STM8 user.
Isn't this supposed just to sit in the interrupt vector table?
Try using the 32-bit word function, or whatever this assembler uses
ie DC.L $82040200
Have you tried IAR, or other STM8 assemblers?
