error on touch key example application
Options
‎2009-08-06 7:36 AM
Posted on August 06, 2009 at 16:36
2 REPLIES 2
Options
‎2011-05-17 6:04 AM
Posted on May 17, 2011 at 15:04I download the touch key control for stm8 but i got following error while compiling example.stw I used cosmic toolchain. I am using license for stm8_16k is this error due to that? #error clnk Debug\example.lkf:1 no default placement for segment .TSL_IO_ALCODE The command: ''clnk -l''C:\Program Files\COSMIC\CXSTM8_16K\Lib'' -o Debug\example.sm8 -mDebug\example.map -sa Debug\example.lkf '' has failed, the returned value is: 1 exit code=1. Please guide me! :o Vaibhav
Options
‎2011-05-17 6:04 AM
Hi Vaibhav,
This is a linker issue, that the pragmma section .TSL_IO_ALCODE is declared in the code but not defined in the linker. Can you please give me the link to download this project? Regards mozra
