COSMIC CXSTM8 - problem with if-else statemant
wolfgang239955_stm1_st
Posted on April 09, 2010 at 16:58
7 REPLIES 7
luca239955_stm1_st
Senior II
Posted on May 17, 2011 at 15:07
we confirm this is a problem in the compiler, please contact me via email (luca.ubiali@cosmic.fr) for the solution.
Luca (Cosmic)
luca239955_stm1_st
Senior II
Hi again,
please disregard my previous message (internal misunderstanding): actually we cannot reproduce your error.
Can you please send me the minimun compilable code showing the problem together with the detailed info on the version you are using?
Luca (Cosmic)
Hi Luca,
thanks for the promt reply. I  took your remarks as suggestion to start further studying - so there are new findings:
Now I'm sure, that the malfunction arises from the fact, that I define the structure as volatile:
@tiny volatile struct  flag_type  flag;
Hope this information will be helpful to you.
WoRo
luca239955_stm1_st
Senior II
Posted on May 17, 2011 at 15:08
we still cannot see the error.
Here is what we tried:
#define N 1
@tiny volatile struct x {
    char b0:N, b1:N, b2:N;
    } x;
void f(void)
    if ((x.b0 = x.b1) == 1)
        x.b2 = 0;
please send us a complete example.
Luca
Hi Luca,
here my minimised program attached.
WoRo
Hi again,
new findings:
Modifying your example strictly according to the rules of ANSI C, the CX educes the known malfunction.
#define N 1
    unsigned int b0:N, b1:N, b2:N, b3:N,
         b4:N, b5:N, b6:N, b7:N, b8:N;
    } x;
void f(void)
        x.b2 = 0;
    } Where using (unsigned) int instead of char -PLUS- a structure of more than 8bits seems to cause the failure.
Regards, WoRo
luca239955_stm1_st
Senior II
Hi Woro,
we fixed the problem, thank you for your analysis.
Luca
