STM8 MCUs
Discuss STM8 microcontrollers, including SWIM, USART configurations, RTC usage, ADC issues, and debugging.
Programming STM8S208C8 with SWIM not working. ST Link V2, Custom PCB.
Everything I'm seeing seems like it should be straightforward. But I have been through everything Google came up with and have tried as many pull up resistor values, configurations, and sequences as I could find and had no luck. Have tried STVD Light...
ESher.1 by Associate
  • 2121 Views
  • 0 replies
What is I2C FREQR register used for?
Hi =) I am using a STM8L151 but I am pretty sure this is the same for any STM8 with i2c.The register I2C_FREQR is described in:page 507 of the RM0031: https://www.st.com/resource/en/reference_manual/cd00218714-stm8l050j3-stm8l051f3-stm8l052c6-stm8l05...
SLasn.1 by Senior
  • 777 Views
STM8L TIM2 PWM Signal Generation
Hello Guys,I am using STM8L board and would like to learn how can I generate a PWM Signal at the output port with TIM2. How should I set the configuration?Thank you
AIpek.1 by Associate
  • 883 Views
  • 1 replies
STM8L Timer Initiation problem
Hello,I am new to ST processors. Here is the issue:I am trying to setup Timer 3 for interrupt, Code: TIM3_DeInit(); CLK_PeripheralClockConfig(CLK_PCKENR1_TIM3, ENABLE); TIM3_TimeBaseInit(TIM3_Prescaler_64, TIM3_CounterMode_Down, 2500);    TIM3_Set...
TXu.2 by Associate
  • 770 Views
  • 1 replies
Resolved! how can i use sprintf()
i want bto use sprintf() in my application what libraries i have to use
Trinu by Associate III
  • 2064 Views
  • 5 replies
How to solve this error???
i am adding stm8s.h header file and getting this error.i dont understand why i am getting this error.errors are...Compiling main.c...cxstm8 -i"..\..\..\..\..\..\..\..\program files\stmicroelectronics\st_toolset\include" -i"..\..\..\data manual\stm8s...
MAnsa.1 by Associate II
  • 1527 Views
Hii I want to turn ON LED
i have positive and negative voltage in the range of 1000v.i connected one LED to indicate minus voltage.led is connected to PD1 of stm8s003f3 controlleri put this condition....#define SevenSegmentDisplays_GPIOD_ODR_ResetValue 0x7E#define SevenSegme...
  • 623 Views
