STM32F7 Discovery, STM32CubeProgrammer
ADębs.1
I cannot connect to program the STMF7 Discovery. In the attached file a message. What to do? regards
Andrzej
Based on your previous posts, I'm guessing you are erasing the flash in your program which can cause the debugger to disconnect during startup. Some solutions here:
https://community.st.com/s/question/0D50X0000B8jTfw/stlink-error-devtargetnothalted
You can always connect with STM32CubeProgrammer (under reset if necessary) and erase the flash to get back to a working state.
