I want to write a TouchGFX hex file using STM32CubeProgrammer
2021-01-17 9:53 PM
Thank you for helping.
environment:
STM32CubeProgrammer Ver2.6.0
TouchGFX Ver4.15.0
Board: STM32F769I-DISCO etc.
Is it possible to write a hex file created by TouchGFX using STM32CubeProgrammer?
I want to write a program to internal and external flash via UART without using SWD.
Thank you.
- Labels:
STM32CubeProgrammer
STM32F7 Series
2021-01-21 11:01 AM
Hi @Ebun.1 ,
Flashing external memory is possible only using SWD.
If you want to use SWD you can use this command:
STM32_Programmer_CLI.exe -c port=swd mode=UR -el ExternalLoader\MX25L512G_STM32F769I-DISCO.stldr firmware.hex
Houda
2021-01-21 11:01 AM
Hi @Ebun.1 ,
Houda
2021-01-21 8:21 PM
Hi Houda
Thank you for your answer.
