MAmem.1
Getting error on Write (download) while Read and Erase command work correctly in .stldr file.
  • June 15, 2022
  • 890 views
I'm trying to download a binary file into an external flash using the STM32CubeProgrammer with an .stldr file.
I can Read, Erase, but the download doesn't work.
The tool start by programming the first 0xFF addresses and stops.
the error is Error: failed to download Segment[0].
Can anyone help please ?
Tesla DeLorean
Guru
June 15, 2022
What Pseudo Address space does the data for your SPI FLASH live in?
You should debug your write code within an application.
The loader can output diagnostic/telemetry via a serial port if you need to debug it in operation.
MAmem.1
MAmem.1Author
It is placed in a declared buffer.
I'm going to debut the write code within an application.
Thank you
