(Windows) STM32CubeMX uninstaller fails when username contains a space
iforce2d
The uninstaller.bat uses a temporary folder like:
set tmp_dir="C:\Users\%USERNAME%\AppData\Local\Temp\MX-JRE-%random%%random%"
Which on my computer becomes like:
"C:\Users\HP 8460p1\AppData\Local\Temp\MX-JRE-73025091"
Then it tries to use xcopy with this path, which does not work. The installer quits prematurely with the message "Invalid number of parameters".
https://stackoverflow.com/questions/30651776/xcopy-returns-error-invalid-number-of-parameters-when-exclude-parameter-is-set
Please fix.
A workaround is to edit the .bat file and hardcode the tmp_dir to some other location which does not contain any spaces.
Khouloud ZEMMELI
Hello @iforce2d​ ,
Thanks for your post,
I checked it from my side, and yes, you're right! As a workaround, I propose you to use first way mentioned in UM under "3.2.3 Uninstalling STM32CubeMX standalone version".
Thank you for raising this issue to our attention, it will be fixed :)
Khouloud
