2019-04-14 8:03 AM
After updating the program from the GUI it doesn't start anymore:
2019-04-14 16:41:18,352 [WARN] Updater:457 - Unsupported task request: 37
Exception in thread "AWT-EventQueue-0" java.lang.ClassCastException: java.base/java.lang.Integer cannot be cast to java.desktop/javax.swing.JPanel
at com.st.microxplorer.maingui.New_gui_UpdateMngrLinePanel.<init>(New_gui_UpdateMngrLinePanel.java:82)
at com.st.microxplorer.maingui.New_gui_RightPanel.<init>(New_gui_RightPanel.java:62)
at com.st.microxplorer.maingui.NewUIStartupPanel.InitStartupPanel(NewUIStartupPanel.java:127)
at com.st.microxplorer.maingui.NewUIStartupPanel.<init>(NewUIStartupPanel.java:69)
at com.st.microxplorer.maingui.MainPanel.initialization(MainPanel.java:247)
at com.st.microxplorer.maingui.MainFrame.initialization(MainFrame.java:148)
at com.st.microxplorer.maingui.MicroXplorer.run(MicroXplorer.java:187)
at com.st.microxplorer.maingui.STM32CubeMX.run(STM32CubeMX.java:25)
at java.desktop/java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:313)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:770)
at java.desktop/java.awt.EventQueue.access$600(EventQueue.java:97)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721)
at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:740)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)Installed java version:
> java --version
openjdk 10.0.2 2018-07-17
OpenJDK Runtime Environment (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4)
OpenJDK 64-Bit Server VM (build 10.0.2+13-Ubuntu-1ubuntu0.18.04.4, mixed mode)Any hints are appreciated - thanks !!
2019-05-06 10:27 AM
a fresh install of version 5.2.0 fixes the problem
