2026-03-15 2:40 AM
Hello, I got following problem.
STM32CubeMX is unable to properly generate .project file for STM32CubeIDE. After clicking "GENERATE CODE", MX is copying library files, generating .h and .c files, but no .project file.
Following nullpointer exception can be found in log file. I already tested different versions of JAVA - no change.
I attached error messages, MX log, and .ioc file.
Anyone managed to fix this?
2026-03-15 10:27:00,707 [ERROR] ToolchainGenerator:531 -
java.lang.reflect.InvocationTargetException: null
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:115) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.CallMethod(ToolchainGenerator.java:406) ~[?:?]
at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.generate(ToolchainGenerator.java:506) ~[?:?]
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:5583) ~[?:?]
at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:987) ~[?:?]
at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:61) ~[?:?]
Caused by: java.lang.NullPointerException: Cannot invoke "Object.hashCode()" because "key" is null
at java.util.Hashtable.put(Hashtable.java:481) ~[?:?]
at sun.rmi.registry.RegistryImpl.rebind(RegistryImpl.java:287) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.rmi.MailBox.connectNewMailBox(MailBox.java:46) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.setupMailBox(PlugIn.java:282) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.doExecute(PlugIn.java:329) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.doGenerate(PlugIn.java:295) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugInAbstract.generate(PlugInAbstract.java:44) ~[?:?]
at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugInAbstract.generate(PlugInAbstract.java:32) ~[?:?]
at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
... 6 more
2026-03-15 2:46 AM
PS:
MX version is 6.17.0
IDE version is: 2.1.0
2026-03-15 3:42 PM - edited 2026-03-16 2:04 AM
Hello @Kopytko
Let me thank you for posting.
I am unable to reproduce the behavior described.
The project was generated correctly, and the compilation completed successfully without any errors.
2026-03-15 3:56 PM
Traces of devil detected in the log. Spray the machine with holy water!
2026-03-24 3:00 AM
Related: Unable to generate FreeRTOS code after migration ?
