How to generate a 1000Hz signal on PC7 using TIM3 or TIM8 on STM32L476QE 80MHz. Using a prescaler 1000.
Eliso
With the SW generated by MX as example I have a timer that seems to work, but not a signal on PC7.
20 REPLIES 20
Hi Very thanks, JW. It is working, it works fine also using the compare without PWM. Eliso I Em sáb., 10 de abr. de 2021 às 17:51, ST Community escreveu:
