Hi all, I am at my led blinking test and works fine. I want to use more GPIOs in it. I do not want to make a new project, I want improve the actual one instead. How can I get back to the initial graphic Cube environment to add new pins? Steve
IReta.1
If you created the project, the IOC file should still be present in the Project Explorer window in STM32CubeIDE. Double click it to open.
You can't convert code to an IOC file (used by CubeMX), if that's what you're asking. You can only go from IOC to code.
IReta.1
A big THANK YOU ! :grinning_face:
