GFX01M2 display expansion board Hello World Demo not working
haspirimla
I'm trying to run the X-NUCLEO-GFX01M2 X-Cube-Display Hello World Demo on my NUCLEO-L476RG board via SPI, but I can't get past the BSP_LCD_Init function. In the lcd_io.c file, a BSP_ERROR_UNKNOWN_COMPONENT error is returned after this condition:
 if((ST7789V_LCD_Driver.ReadID(LcdCompObj, &id) == ST7789V_OK) && (id == ST7789V_ID))
is not fullfilled.
FBL
Hello @haspirimla
Have you tried using the LCD example provided with X Cube package? Actually, this package has been tested using ILI9341_LCD_Driver. So, you may need to make some adjustments.
Best regards,
FBL
