CubeMx erroneous behaviour
Posted on June 15, 2018 at 11:20
1.  Cube?? version 4.26
2 . Device STM32F429ZI
3. Erroneous module  usbd_conf.c
4 Erroneous functions HAL_PCD_MspInit, HAL_PCD_MspDeInit
5. CubeMX configuration   see attached conf file.
5. Description.
when both usb ports configured as devices or/and hosts with any registered class , inside HAL_PCD_MspInit function  is not contained initialization code for both ports  but for FS only (some times under certain circumstances , for HS only).
#st32cubemx
0 REPLIES 0
