CubeMX Configuration and Wiring for CAN Communication Using Simulink Models
Hikaru
Visitor
We are considering a system configuration in which a model created in Simulink is programmed onto an STM32 microcontroller, and CAN communication (both transmission and reception) is performed.
In this context, we would like to ask for your recommendations regarding:
  • STM32CubeMX configuration required for CAN communication
  • Key hardware wiring points and precautions when using CAN
We would appreciate it if you could share any recommended settings or best practices from STMicroelectronics.
In particular, we would be grateful for your advice on any points to consider regarding consistency between CubeMX configuration/initialization code and code generated using Simulink and Embedded Coder.
Andrew Neil
Not quite sure what you mean by this ?
The operation of Simulink is beyond the scope of this forum - it's nothing to do with ST - so you'd need to discuss that with MathWorks:
https://uk.mathworks.com/support/contact_us.html?s_tid=hc_resources
https://uk.mathworks.com/help/?s_tid=nav_help_doc
https://uk.mathworks.com/help/simulink/index.html?s_tid=hc_panel
https://uk.mathworks.com/matlabcentral/?s_tid=user_nav_community
Andrew Neil
Hello @Hikaru ,
I confirm @Andrew Neil 's saying.
We can help you with CAN issues using HAL but unfortunately not with Simulink.
