windows executable from Cubemonitor flow
‎2025-03-23 8:58 AM
Dear all,
haven´t yet found topic like this.
I would like to...(need) make a windows executable file / application from a Cubemonitor flow.
Any Idea if and how possible?
Thanks and have a great day!
‎2025-03-23 11:23 AM
Here you can find help for your request.
https://www.fiverr.com/categories/programming-tech/software-development/desktop-applications
‎2025-03-23 11:25 AM
it´s not a request, it´s a question.
thanks! (sarcastic)
‎2025-03-23 1:23 PM - edited ‎2025-03-23 1:24 PM
Answer: pretty much is possible. Depends on your motivation.
Basically you need to wrap the CubeMonitor executables, javascript runtime, interface (USB?) driver, their dependencies together, zip that (or make a nice installer). Maybe make a custom launcher. Not a rocket science but takes some effort. This task is a good candidate for outsourcing to fiverr.
‎2025-06-18 8:02 AM
We have a similar need. If necessary, the installation can be done manually. However, once the installation is complete, the user should not be able to view or modify the design. Is there a way to achieve this?
Thank you, and good work.
‎2025-06-18 8:11 AM
@Ufuk.Akkaya wrote:We have a similar need.
Would probably be better to start a new thread of your own, and give a full description of your actual use case, and what you actually need.
You could always give a link to this thread, for reference.
But I'm not sure this is the kind of thing ST intend the CubeMonitor to be used for ...
